Issue with exception handler
I am facing an issue where I am setting timer at Guest EL1 (NS) mode and trying to route this interrupt to EL2.
I do see that when timer expires the interrupt is pending (using generic timer PPI 30) in GICD_ISPENDR (bit 30 set) but control reaches to first entry in EL2 exception vector rather then IRQ handler vector ?
I do set the HCR_EL2 (IMO) bit to 1 in order to route all IRQs. I am confused as how the control can reach to first entry in exception vector (EL2t Synch handler) ?
I am not sure for v8 if is there any extra configuration step ?
Thanks,
  • Hello,
    Are you sure that you aren't actually entering the vector table at the IRQ entry for a lower EL, but then somewhere in your handler you're taking a synchronous exception and this is taking you to that entry? The simplest way to test this would be to put a branch-to-self at the start of each of your vector table entries, then test the code again, then use a debugger to interrupt the core after the timer expires, and then see where the core is.
    Please can you try this, and then provide the values of the following registers:
    • PC
    • VBAR_EL2
    • ESR_EL2
    This will help to narrow down the issue.
    Ash.
  • Hi Ash,
    I found out the issue was as WFI was trapping. I disabled to trap it in EL2 and it works.
    Now i am facing another issue is that even timer condition is asserted it is not generating interrupt.
    I would like to know from EL1 (NS) mode is it possible to see GIC GICD_IGROUP registers ?
    Is there any document which specify the access permissions for GICv2 registers from different ELx ?
    I am trying to narrow down as why the timer interrupt is not firing even though the condition is getting asserted.
    Thanks,
  • Hello,
    The Generic Interrupt Controller Architecture Specification Version 2 (GICv2) documentation can be found here. Note that you'll need to create a free account in order to download the PDF.
    From Section 4.3.4 Interrupt Group Registers GICD_IGROUPRn, under usage constraints:
    In implementations that include the GIC Security Extensions, accessible by Secure accesses only. The register addresses are RAZ/WI to Non-secure accesses.
    So, a few things to keep in mind:
    • GICD_IGROUPRn must be configured while still in the Secure world such that any Non-secure interrupts are Group 1
    • GICC_PMR must be configured (on all cores) while still in the Secure world to a low enough value that it is writeable by Non-secure accesses
    Then, in EL1-NS, you can enable the interrupt by following these steps:
    1. Enable the GIC Distributor via GICD_CTLR (once by primary core)
    2. Configure GICD_ITARGETSRn to target the interrupt at specific core(s) (once by primary core)
    3. Configure GICD_IPRIORITYRn to set the priority of the interrupt (on all targeted cores)
    4. Configure GICC_PMR to a lower priority than the one set for GICD_IPRIORITYRn (on all targeted cores)
    5. Configure GICD_ISENABLERn to enable the interrupt (on all targeted cores)
    6. Enable the GIC CPU Interface via GICC_CTLR (on all targeted cores)
    7. Use "MSR DAIFClr, #0b0010" to unmask IRQs (on all targeted cores)
    I hope that helps,
    Ash.
