Hi all
I want to use copy_to_user to copy data to kernel space buffer.
I have following test:
mm_segment_t fs;
char *src, *dsr;
int ret;
fs = get_fs();
set_fs(KERNEL_DS);
src = kmalloc(0x10, GFP_KERNEL);
dst = kmalloc(0x10, GFP_KERNEL);
ret = copy_to_user(dst, src, 0x10);
set_fs(fs);
If test run in kernel version 5.10, ret = 0x10, if run in kernel verion 4.19, ret = 0x0.
I have checked the ttbr0_el1/ttbr1_el1/tcr_el1, all seems well, I also checked the pagetable of src/dst in kernel 5.10 and in kernel 4.19 separately, look like same.
I also digged into the copy_to_user, found that dst pagefault in kernel 5.10, finally reach to the lable 9998 of __arch_copy_to_user, if I change x0 to 0 after 9998, copy_to_uesr got 0x0.
If something I missed in kernel 5.10? If anyone could give me some advice
I guess that Kernel 5.10 enhances the security check for memory protection. Maybe your detailed logs can help further analysis.
In your example code, dst pointer is a kernel space memory (it should be user space memory) , which doesn't obey the API expectation of __copy_to_user().
unsigned long __copy_to_user (
void __user * to
Destination address, in user space.
const void * from
Source address, in kernel space.
unsigned long n
Number of bytes to copy.
Hi ZhiFei,
Thanks for your answer.
copy_to_user used to access user space address, but it could also access kernel space address if set_fs(KERNEL_DS)
Cortex A53 can't support UAO, so unprvilege instruction can't access kernel space address
