I'm new to bare metal programming and FPGA's.
I started by learning a little bit on the Arria V SoC developer kit from online resources and executed a bare metal "hello world" program using a preloader (first stage only without uboot) built by bsp-editor GUI.
My next task is to import that "hello world" into a custom board with Arria V SoC (arm cortex a9).
I need some guidance regarding how and from where to start.
- Which base config files I can use "as is" and which I need to modify.
- Can I use the same build tools and procedure as I worked with the devkit?
- What I need to do in order to "port" my built preloader to the new custom board?
- Any further help is much appreciated (when you don't know you don't know what to ask)
Thank you very much.
HiSorry, I can't really help, but I believe your questions would be better posed on the Intel forums, such ascommunity.intel.com/.../fpga-soc-cpld-boards-kitsandcommunity.intel.com/.../programmable-devicesStephen
Thank you very much
