Debugger is disconnecting abruptly without quit command
Hello All,
We are trying to do automation to run the tests using debugger. But when we run debugger using script.ds (have load and run commands). After run command it is disconnecting abruptly. Need a solution to run the script and disconnects when it hit quit command.
script.ds
load myexample.axf
run
0
