I build the EDK II(UEFI) Firmware that generate the .fd file and using this file in Arm trusted firmware the BL1.bin and FIP.bin files are created. Can we directly burn that files on physical board?
If yes then any memory location is required for that files and which memory locations that are? and If no then which files are required for for physical board and how to create that and how to burn on board means any memory location?
