System can not receive uart_pl011 interrupt signal on FVP(qemu_cortex_a53)
hello, arm expert.
I am try to run zephyr-os on FVP(qemu_cortex_53), and when I using uart_pl011, I cannot receive the uart signal on the system. For testing the code, I run the same code on qemu_cortex_a53 platform, and it can work well, So I  guess that is there any addition fvp configuration I need to do to make the uart_pl011 can produce interrupt signal correct. Below is my fvp  parameters:
-C bp.secure_memory=0
-C bp.refcounter.non_arch_start_at_default=1
-C bp.pl011_uart0.out_file=-
-C bp.pl011_uart0.unbuffered_output=1
-C bp.terminal_0.start_telnet=1
-C bp.vis.disable_visualisation=1
-C bp.vis.rate_limit-enable=0
-C gic_distributor.ARE-fixed-to-one=1
-C gic_distributor.ITS-device-bits=16
Thanks, waiting for your reply!
  • I believe the FVP options above are valid.
    Arm Development Studio provides a startup_Cortex-A53x1_AC6 example, that outputs on this UART without issue. You may wish to compare your code with that, notably the UartInit() code in uart.c.
  • Thanks, I have tested it, and it can work well for timer irq. And then I tested the code and found it is because the zephyr system can not receive the uart irq signal, So I think it may be something wrong when I configure the GICv3 device, or I need to enable some gic parameters for correct irq route.
  • I follow the startup_Cortex-A53x1_AC6 example to init my gic, but it dosen't work too, and I don't konw reason. So I want to know is there some pl011 uart's trigger example? Because the example seems like triggered by timer irq. Thanks for your reply.
