I am currently developing an FPGA architecture on Smartfusion2, where the cortex-m3 should control and update the different FPGA cores' registers. I exported the firmware using Libero SoC and created a "C" application using SofConsole 4. The issue is when I debug the program it shows this error: No source available for "0x0"
The full log is listed below:
Open On-Chip Debugger 0.8.0 (2015-10-14-11:51)
Licensed under GNU GPL v2For bug reports, read openocd.sourceforge.net/.../bugs.htmlM2S150Info : only one transport option; autoselect 'jtag'adapter speed: 2000 kHzcortex_m reset_config sysresetreqtrst_only separate trst_push_pulldo_board_reset_initStarted by GNU ARM EclipseInfo : FlashPro ports available: E2001O6WGWInfo : FlashPro port used: E2001O6WGWInfo : clock speed 2000 kHzInfo : JTAG tap: M2S150.tap tap/device found: 0x1f8061cf (mfg: 0x0e7, part: 0xf806, ver: 0x1)Info : JTAG tap: M2S150.tap disabledInfo : JTAG tap: M2S150.dap enabledInfo : M2S150.cpu: hardware has 6 breakpoints, 4 watchpointsInfo : accepting 'gdb' connection from 3333undefined debug reason 7 - target needs resetInfo : JTAG tap: M2S150.tap tap/device found: 0x1f8061cf (mfg: 0x0e7, part: 0xf806, ver: 0x1)Info : JTAG tap: M2S150.tap disabledInfo : JTAG tap: M2S150.dap enabledtarget state: haltedtarget halted due to debug-request, current mode: Thread xPSR: 0x01000000 pc: 0x0000da34 msp: 0x20003308lr (/32): 0x00000000semihosting is enabled===== arm v7m registers(0) r0 (/32): 0x40020A1C(1) r1 (/32): 0x20003D7A(2) r2 (/32): 0x00000000(3) r3 (/32): 0x40020800(4) r4 (/32): 0x7560B55A(5) r5 (/32): 0x7C7713B7(6) r6 (/32): 0x66BD96FB(7) r7 (/32): 0x2000FFD8(8) r8 (/32): 0x4ADDDF59(9) r9 (/32): 0xE7BE1FF0(10) r10 (/32): 0xC5BB6FEF(11) r11 (/32): 0x00000000(12) r12 (/32): 0xE2AFEA71(13) sp (/32): 0x20010000 (dirty)(14) lr (/32): 0x00000000 (dirty)(15) pc (/32): 0x20000190 (dirty)(16) xPSR (/32): 0x01000000 (dirty)(17) msp (/32): 0x20003308(18) psp (/32): 0x9A53960C(19) primask (/1): 0x00(20) basepri (/8): 0x00(21) faultmask (/1): 0x00(22) control (/2): 0x00===== Cortex-M DWT registers(23) dwt_ctrl (/32)(24) dwt_cyccnt (/32)(25) dwt_0_comp (/32)(26) dwt_0_mask (/4)(27) dwt_0_function (/32)(28) dwt_1_comp (/32)(29) dwt_1_mask (/4)(30) dwt_1_function (/32)(31) dwt_2_comp (/32)(32) dwt_2_mask (/4)(33) dwt_2_function (/32)(34) dwt_3_comp (/32)(35) dwt_3_mask (/4)(36) dwt_3_function (/32)
Does anyone have an idea to solve it?
thanks
