ARM Cortex A-8 Bare-metal application with uboot
In Beaglebone Black I'm trying to run a baremetal program (UART0 running in polling mode) from SDCard.
I'm using Uboot as Second stage bootloader to load and run the baremetal program and it is configured with default config “am335x_evm_defconfig”.
Compiled both Uboot and baremetal program with ARM toolchain gcc-arm-none-eabi-10.3-2021.10. Copied MLO, u-boot.img and helloworld.bin (baremetal program) to the SD-Card.
Baremetal program is written without vector table as FIQ and IRQ are disabled.
With reference to AM335x ARM® Cortex -A8 Microprocessors TRM, I found the below RAM addresses to load the application from uboot.
From section 2.1 ARM Cortex A8 Memory Map
  • EMIF0 SDRAM - Start_address (0x8000_0000), End_address(0xBFFF_FFFF), Size(1GB)  - 8-/16-bit External Memory
From section 26.1.3.2 Public RAM Memory Map
  • Public RAM memory map ranges from address 0x402F0400h to 0x4030FFFFh on a GP Device
I'm trying to load and run the baremetal application from both RAM address, both are not working as expected.
Load application to the RAM address 0x402f0400 from uboot:
$ fatload mmc 0 0x402f0400 helloworld
getting on fatload command "trying to overwrite reserved memory…"
Loading and running application from RAM address 0x80000000 from uboot:
$ fatload mmc 0 0x80000000 helloworld
$ go 0x80000000
baremetal program is running, but soon the target is restarting.
Below is the start-up code of the bare-metal application:
Below is the linker script of the baremetal program:
I'm new to the bare-metal programming and Cortex-A8 architecture and it's memory mapping.
I would like to get feedback from the ARM experts.
Please let me know any more details are needed from my side.
Please guide me.
Thanks.
0
