Hello , can some one let me know if they are working on ARM neon XOR implementation , i am able to do basic calculation however looking for optimization techniques available.
Also i see that my output results are not stable as they are keep on changing for the same program.
Regards,
Praveen
I'm a little bit confused by your questions.
I recommend you repost your 2nd question to the ARM Processors community, as it doesn't really seem to be specific to the Juno and more people that can potentially help you will see it there. You will need to provide a lot more information though, such as a reproducible test case with the offending source code.
Ash.
