JUNO SoC provides additional support for virtualization except Cortex-A57/A53 as follows:The CoreLink GIC-400.Stage 2 page table translation for masters, that the following provide:A CoreLink MMU-401 System Memory Management Unit (SMMU) for the following: - The Embedded Trace Router (ETR). - PCI Express. - Each HDLCD controller. - The DMA-330. - Thin Links, TLX-400.A CoreLink MMU-400 SMMU for the Mali-T624 GPU.Note: The MMU-400 does not support the AArch64 page table format.
1. Since MMU-400 is only compatible with ARMv7 LPAE page table formats, why does it connect with Mali-T624 GPU for virtualization in a ARMv8 SoC?2. MMU-401 is compatible with ARMv7 and ARMv8, but it only supports Stage 2 address translation. I find that Stage 1 address translation is mainly useful for memory fragmentation management and Stage 2 address translation is intended to benefit Virtual Machine Monitors from System-MMU-Whitepaper-v8.0.pdf. The masters that connect with MMU-401 in JUNO SoC don't have their own MMU, so do the outside SMMUs need also support Stage 1 address translation for memory fragmentation management and virtualization?Does Stage 2 address translation also support memory fragmentation management?
3.Why not directly use MMU-500 for virtualization in JUNO SoC?
I also want to know the answer.
songbin please pay attention to, thanks.
Note that the official support channel for Juno is email. See this FAQ.
This is a true forum, so there's no guarantee that posts will receive an answer, especially for open questions such as this. I've replied to the thread author's original post, but if you have follow up questions (and an entitlement to support), please email juno-support@arm.com.
Thanks,
Ash.
1. A few things to note for this one:
2. The most common use-case for an SMMU is to allow other masters (DMA, GPU, etc) to see the same view of memory as the operating system, and for this we only need the 2nd stage of translation. This allows for the same driver code to be used in both virtualised and non-virtualised systems without costly trapping in software to the hypervisor. An SMMU supporting 1st stage translations would be useful for implementing userspace drivers, especially for scatter-gather scenarios such as sharing sparse memory buffers, i.e. making non-continguous blocks of physical memory appear as a single contiguous block in the virtual address space.
3. This is most likely because the MMU-500 wasn't available at the time that the Juno SoC was being designed.
I hope this helps,
Thanks a lot. Great answers.
