Gator/Streamline support for both A57/A53
When connecting Streamline to Juno, all I see are A53 counters.  Any chance of getting the A57 (or better yet both) sets of counters or is HMP Streamline fundamentally broken?
    -eric
  • Streamline/gator should be able to pick up both sets of counters. However having just got access to a board I think I have observed similar behaviour. I'll let the Streamline team know and see if we can make some progress.
    Standby for more...
  • Hi Eric,
    The issue is that the Linux kernel does not currently support collecting data from multiple CPU PMUs. As such it only displays one of the PMUs - in the case of the Juno development platform it chooses the Cortex-A53's PMU.
    There is a fix to the kernel currently being prepared to address this problem.
    In the mean time while you are not able to see the Cortex-A57's counters explicitly, there is sufficient similarity between the cores that collecting the Cortex-A53's counters will allow you to read most values from the Cortex-A57 cluster as well - i.e. if you collect data from a Cortex-A53 counter it will, providing that counter exists on the Cortex-A57 as well, collect from both clusters.
    Once the Linux kernel supports having multiple types of PMU counters it should work as expected.
    Hope that helps,
    Jon
  • Yes, it seems like the common counters work, but we are observing that certain counters only report values when the A53s are active (things like branch: mispredicted, l2 data access, etc.  So seems like things are really bad off unless you are only measuring on the A53s.
  • Hi,
    Has the latest linaro kernel fixed this issue?
    Please let me know.
    Thanks,
    Biswa
  • Hi Biswa,
    I'm afraid this has not been resolved yet. I don't have any estimates about how long it will take but it is likely still several months away.
    Sorry,
    Jon
