Rowhammer bug on ARMv8
Hi Everyone,
I have been trying exploiting Rowhammer bug on ARMv8 running linux for a university project.
The device is a Quad core Cortex-A72 (ARM v8) 64-bit SoC @ 1.5GHz.
First i checked the UCI bit value in the SCTLR register, and is set. So the unprivileged instructions to flush the cache are enabled.
The pseudocode  is:
Fullscreen
1
2
3
4
5
6
7
put addr1 into X9
put addr2 into x10
for i:= 0 to N−1 do
STR X0, [X9]
STR X0, [X10]
DC CIVAC, X9
DC CIVAC, X10
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
I'm using two approaches to exploit Rh bug:
First approach is based on using unprivileged instructions to flush the cache (DC CIVAC, DC CVAC).
Using timing measurements  i can get two addresses SBDR (Same Bank Different Rows) addr1 and addr2, and then i'm ready to run my rh loop:
Fullscreen
1
2
3
4
5
6
7
8
9
10
11
12
13
for (int i = 0;i<HAMMER_ROUND;i++){
asm volatile(
"str %2, [%0]\n\t"
"str %2, [%1]\n\t"
"dc cvac, %0\n\t"
"dc cvac, %1\n\t"
//"dsb 0xb"
::"r" (addr1),
"r" (addr2),
"r" (temp)
The second approach is based on bypassing the cache using DC ZVA instruction.
In this case, i allocated a memory pool and set it to 0 value.
Fullscreen
1
2
3
4
5
6
7
8
9
asm volatile(
"dc civac, %0\n\t"
"dc civac, %1\n\t"
::"r" (addr1), "r" (addr2)
for (int j = 0; j < HAMMER_ROUND; ++j) {
__asm__ __volatile__("dc zva, %0\n\t" : : "r" (addr1) :"memory");
__asm__ __volatile__("dc zva, %0\n\t" : : "r" (addr2) :"memory");
I have no bit flips.
My question is : am i using those instructions right ?
Thank you.
0
