Im trying to connect our website to a Application Insights component via ARM but havning troubles in setting the Intstrumentation Key as an website application setting. This works sometimes and sometimes not.
My guess is that i m having incorrect dependsOn settings. Can anyone have a look on my template and see if i m doing something wrong? Have a look on the resource called "appSettings" of type "config" in the website resource. Here I am supposed to wait for completion of the Application Insight and then read the Instrumentation Key.
{ "name": "[variables('webAppNameFinal')]", "type": "Microsoft.Web/sites", "location": "[parameters('appServicePlanLocation')]", "apiVersion": "2015-04-01", "dependsOn": [ "[concat('Microsoft.Web/serverfarms/', variables('appServicePlanNameFinal'))]" ], "tags": { "[concat('hidden-related:', resourceGroup().id, '/providers/Microsoft.Web/serverfarms/', variables('appServicePlanNameFinal'))]": "Resource", "displayName": "webApp" }, "properties": { "name": "[variables('webAppNameFinal')]", "serverFarmId": "[variables('appServicePlanNameFinal')]" }, "resources": [ { "apiVersion": "2015-04-01", "name": "connectionstrings", "type": "config", "dependsOn": [ "[resourceId('Microsoft.Web/Sites', variables('webAppNameFinal'))]", "[resourceId('Microsoft.Sql/servers', variables('sqlServerNameFinal'))]" ], "properties": { "Watches": { "value": "[concat('Server=tcp:', reference(concat('Microsoft.Sql/servers/', variables('sqlServerNameFinal'))).fullyQualifiedDomainName, ',1433;Database=', variables('sqlDatabaseNameFinal'), ';User ID=', parameters('sqlServerAdminLogin'), ';Password=', parameters('sqlServerAdminLoginPassword'), ';Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;')]", "type": "SQLAzure" } } }, { "apiVersion": "2015-08-01", "name": "appsettings", "type": "config", "dependsOn": [ "[resourceId('Microsoft.Web/Sites', variables('webAppNameFinal'))]", "[concat('Microsoft.Insights/components/', variables('applicationInsightsNameFinal'))]" ], "properties": { "Watches.Webjobs.VitecConnect.WatchersExport.Run": "false", "ApplicationInsights.InstrumentationKey": "[reference(concat('Microsoft.Insights/components/', variables('applicationInsightsNameFinal'))).InstrumentationKey]" } }, { "apiVersion": "2015-04-01", "name": "web", "type": "sourcecontrols", "dependsOn": [ "[resourceId('Microsoft.Web/Sites', variables('webAppNameFinal'))]" ], "properties": { "RepoUrl": "[parameters('gitUrl')]", "branch": "[parameters('gitBranch')]" } }, { "apiVersion": "2015-08-01", "name": "web", "type": "config", "dependsOn": [ "[resourceId('Microsoft.Web/Sites', variables('webAppNameFinal'))]" ], "properties": "[variables('siteProperties')]" } ] }, { "name": "[variables('applicationInsightsNameFinal')]", "type": "Microsoft.Insights/components", "location": "Central US", "apiVersion": "2014-04-01", "dependsOn": [ ], "tags": { "displayName": "Application Insights" }, "properties": { "applicationId": "[variables('webAppNameFinal')]" } },
