My Juno board sometimes comes up with "IP-Config: Failed to open eth0" and uses eth1 instead, causing my Android start-up to fail as it will only use eth0. Any idea why this might happen? Power cycling the board fixes the problem.
Hi Marcus - this sounds like an issue we need to look at. Please can you raise a defect internally.
Thanks,
Steve
You should only see one ethernet card with the Alpha release. I would like to see a copy of the kernel log when the failure happens.
marcuso, is your problem addressed?
If it has, may I advise you to close the question?
Otherwise, could you provide the log Liviu was referring to?
New version of kernel now being used which does not have the problem.
Great news, I'm closing this then!
