questions about vttbr_el2
In the ARM Architecture Reference Manual ARMv8, for ARMv8-A architecture profile, there's a description about vttbr_el2: " Register bits[47:x] hold bits[47:x] of the stage 1 translation table base address" . I am a little confused, as far as I know , the vttbr_el2 register hold the stage 2 page table base address, so what's the meaning of " stage 1 translation table base address"?
Also, I tired to open the 2 stage paging in my system. I setup the 2 stage page table at  physical address(0x20000000), and set the vttbr_el2 to this value.However, I got a Data Abort (code: 000101) which means a level 1 translation fault in stage 2 translation. So what's the correct usage of  vttbr_el2?
I am using cortex-a53 and here's the related register value I set:
HCR: 0x80000001
VTCR_EL2: 0x80023558
VTTBR_EL2: 0x20000000
  • I am a little confused, as far as I know , the vttbr_el2 register hold the stage 2 page table base address, so what's the meaning of
    Yes, unfortunately that looks like a docs error, I raise it with the docs team.
    On the abort, I don't see anything obviously wrong with the register values.  What values do you get in ESR_EL2 and HPFAR_EL2, and what have you populated the translation table with?
  • Thanks for your reply.
    Actually, I test the address translation in el3 using AT S12E1R,0x10000000 instruction. So I get the result from PAR_EL1 of which the value is "0xa0b"( means the FST code is 0b000101).
    In the level 1 page table , I map the 0-1GB space using a block descriptor. The table descriptor at address 0x20000000 is 0x7fd.
    The strange thing is,  when my system is booting up, I sometimes can get the correct translation while sometimes not. I am wondering wether this is because there are some other system registers which can influence the stage 2 translation which I doesn't set and it reset to a unknown value.
    I will appreciate it if you could give me any help.
  • Are you invalidating the TLBs before enabling second stage translation?
    Also, if you contact Arm Support they might have example code that can be shared.
  • Yes, I invalidated the TLBs by " TLBI ALLE1IS" and "TLBI ALLE2IS". I will try to contact Arm Support for some example code.
    And thanks for your help!
