TLB Conflict abort
Hi All,
I want to check TLB Conflict abort.
How can I create an address which matches multiple entries in the TLB as ARMv8 spec mentioned.
ARMv8 spec:
"An address can hit multiple entries in the TLB if the TLB has been invalidated inappropriately, for example if TLB
invalidation required by the architecture has not been performed."
Thanks,
  • It's quite hard to come up with a sequence which definitely generates the exception, as you don't have precise control of the MMU.  But try something like this:
    • Map a 4KB page (address X)
    • Touch that page, in order to get the translation cached in the TLB
    • Modify the translation tables, replacing the mapping for address X with a 2MB mapping - DO NOT INVALIDATE the TLB
    • Touch "X + 4KB".  This will/should miss in the TLB, causing a new walk returning the 2MB mapping
    • Touch X.  Assuming they've not been evicted, you'll hit both on the 4KB and 2MB mapping - as both cover address X.
  • Thanks!
    I could create an address matches 2 entries as your suggestion but the TLB Conflict abort was not generated with ARM model.
    1. First memory access: Address cached in the TLB (4KB)
    clk TLB FILL cpu0.UTLB 4K 0x8180000000_NS EL2_n, nG asid=0:0x8180000000_NS
    2. Second memory access: Address cached in the TLB (2MB)
    clk TLB FILL cpu0.UTLB 2M 0x8180000000_NS EL2_n, nG asid=0:0x8180000000_NS
    3. Final memory access: Expect TLB conflict abort but not happened.
    It seems TLB not only cached the address but also the size etc, combining all conditions it's hard to create TLB conflict.
  • Which model are using?  If it's the AEM FVP, you need to enable TLB conflict reporting:
    -C cluster0.has_tlb_conflict_abort=1
    -C cluster1.has_tlb_conflict_abort=1
    Or, for the single cluster systems:
    -C cluster.has_tlb_conflict_abort=1
