Hello, I am a student of Master’s Degree in Embedded Computing Systems offered by Sant’Anna School of Advanced Studies and the University of Pisa. I am carrying out a cyber security thesis project focusing in particular on Pointer Authentication of ARM. I have some questions: 1) why do you need XPAC * instruction? Is not it a problem for security in case of an attack? If so, is it possible to trap only the use of this instruction for a certain exception level? 2) When an authentication fails, a translation faults occurs. Is it possible to know, from the values of registers, that this is given by a failed authentication and not for another reason? 3) What types of attacks PAC can block and which ones do not? 4) Which ARM processors implement PAC?
Giulia Ferri said:1) why do you need XPAC * instruction? Is not it a problem for security in case of an attack? If so, is it possible to trap only the use of this instruction for a certain exception level?
Computer attacks are becoming more sophisticated. Examples of this are exploit mechanisms such as the use of gadgets in Return-Orientated-Programming (ROP) and Jump-Orientated-Programming (JOP). To mitigate against such exploits, Armv8.3-A introduces a feature that authenticates the contents of a register before it is used as the address for an indirect branch or data reference. HCR_EL2, SCR_EL3 System register controls that trap accesses to Pointer authentication functionality: Traps to EL2/3 any use of an enabled Pointer authentication instruction.
Giulia Ferri said:2) When an authentication fails, a translation faults occurs. Is it possible to know, from the values of registers, that this is given by a failed authentication and not for another reason?
New instructions are added which can be used to: * Insert a PAC into a pointer * Strip a PAC from a pointer * Authenticate strip a PAC from a pointer If authentication succeeds, the code is removed, yielding the original pointer. If authentication fails, bits are set in the pointer such that it is guaranteed to cause a fault if used.
Giulia Ferri said:3) What types of attacks PAC can block and which ones do not?
Giulia Ferri said:4) Which ARM processors implement PAC?
arm processors which support ARMv8.3-PAuth, Pointer Authentication, currently there's no processor support ARMv8.3-PAuth.
The ARMv8.3 pointer authentication extension adds functionality to detect modification of pointer values, mitigating certain classes of attack such as stack smashing, Return-Orientated-Programming (ROP) and Jump-Orientated-Programming (JOP). System register HCR_EL2/SCR_EL3 controls that trap accesses to Pointer authentication functionality: Traps to EL2/3 any use of an enabled Pointerauthentication instruction
making stack smashing, Return-Orientated-Programming (ROP) and Jump-Orientated-Programming (JOP) hard
Next generation processor that support armv8.3, PAuth, currently there's no such processor.
Thank you for your answer.
some things are not clear to me yet.for question 1, I would like to know why the instruction for strip a PAC from a pointer is designed. In which cases is it useful?for question 2, I would like to know more specifically if and how it is possible to understand that the translation fault is due to the failure of authentication by reading the registers. I would like to handle the fault only if the translation fault is caused by the failure of the authentication of a PAC.
Hi Giulia,
1. Library code performing stack unwinding may need to use XPAC* rather than attempting authentication and/or acquiring the PAC masks via ptrace.
And kernel perf will use xpac* when unwinding, here's an example:
https://patchwork.kernel.org/patch/10077257/
2. If the check fails, the second-top and third-top bits of the extension bits in the pointer authentication code field are corrupted to ensure that accessing the address will give a translation fault. Can check this error bits of the fault address if identify if it's a pac fault.
