I trying to include .s file into another .s file using INCLUDE directive with defined parameter, but without success.
I check 2 scenario.
Scenario 1
startup.s file:
#include "Configuration.h" #if defined (CONF_CHIP_ID_LPC1549JBD64) INCLUDE CONF_ARMHAL_STARTUPSFILE ... ; some asm code #endifEND
And "Configuration.h" file:
#define CONF_CHIP_ID_LPC1549JBD64 1#define CONF_ARMHAL_STARTUPSFILE "..\..\..\ARM_HAL\startup_LPC15xx.s"
After compile I give an error:
.....\startup.s(17): error: A1023E: File ""..\..\..\ARM_HAL\startup_LPC15xx.s"" could not be opened: No such file or directory
- Please look at double quote at filename!
Scenario 2
In "Configuration.h" file, I was changed value of CONF_ARMHAL_STARTUPSFILE parameter, to without quote :
#define CONF_CHIP_ID_LPC1549JBD64 1#define CONF_ARMHAL_STARTUPSFILE ..\..\..\ARM_HAL\startup_LPC15xx.s
....\startup.s(17): error: A1023E: File ". .\. .\. .\ARM_HAL\startup_LPC15xx . s" could not be opened: No such file or directory
- Please look at additional spaces in filename!
Please, what's wrong in C preprocessor? Is any way how to include file, defined by #define parameter?
Thank you.
This code is part of C project written in uVision IDE. Parameter "--cpreproc" is used for assembler.
ARMCC c5.06 update 5
ARMASM v5.06 update 5
