binutils 2.44 and GCC 15.1.0 - dangerous relocation: unsupported relocation error when trying to build U-Boot
Hello Community!
I have freshly built the new version from GCC (15.1.0) and binutils (2.44) for arm-none-eabi targets. Have tried to build U-Boot for STM32H743 (ARMv7-m), but running into an issue when linking U-Boot:
  LD      u-boot
arm-none-eabi-ld.bfd: warning: -z norelro ignored
arm-none-eabi-ld.bfd: arch/arm/cpu/armv7m/start.o(c_runtime_cpu_setup): Unknown destination type (ARM/Thumb) in arch/arm/lib/crt0.o
arch/arm/lib/crt0.o: in function `_main':
/home/jk/Projects/U-Boot/src/arch/arm/lib/crt0.S:170:(.text+0x44): dangerous relocation: unsupported relocation
make[1]: *** [/home/jk/Projects/U-Boot/src/Makefile:1824: u-boot] Error 1
make[1]: Leaving directory '/home/jk/Projects/U-Boot/build'
make: *** [Makefile:177: sub-make] Error 2
By the way, with GCC 14.2.1 and binutils 2.43.1 the compilation is successful.
Has somebody noticed the same issue?
  • I have fixed the issue. Since binutils version 2.44 functions in assembly must include the assembler directive .type name, %function, otherwise they fail at linking.
    This is described in a Git log from the binutils-gdb repository.
    So in the source from U-Boot I added the missing and required .type c_runtime_cpu_setup, %function. under arch/arm/cpu/armv7m/start.S.
  • Thank you for coming back to share the solution you found with the community.
  • No problem.
    For U-Boot I have released a patch to the U-Boot mailing list. It's reviewed by a maintainer, but currently not added into the official U-Boot Git repo.
    Simple copy & paste from the patch (but removed the mail addresses):
    Subject: [PATCH v2 1/1] arm: cpu: armv7m: add ENTRY/ENDPROC macros
    Since GNU binutils version 2.44, assembly functions must include
    the assembler directive .type name, %function. If not a call to
    these functions fails with the error message 'Unknown destination
    type (ARM/Thumb)' and the error message 'dangerous relocation:
    unsupported relocation' at linking.
    The macros ENTRY/ENDPROC includes this directive and should be
    used for all assembly functions.
    Signed-off-by: Johannes Krottmayer <MAILADDR-REMOVED>
    Cc: Tom Rini <MAILADDR-REMOVED>
     arch/arm/cpu/armv7m/start.S | 20 +++++++++++++-------
     1 file changed, 13 insertions(+), 7 deletions(-)
    diff --git a/arch/arm/cpu/armv7m/start.S b/arch/arm/cpu/armv7m/start.S
    index 0c07f2140c7..3355167b3b0 100644
    --- a/arch/arm/cpu/armv7m/start.S
    +++ b/arch/arm/cpu/armv7m/start.S
    @@ -4,13 +4,19 @@
      * Kamil Lulko, <MAILADDR-REMOVED>
    +#include <linux/linkage.h>
     #include <asm/assembler.h>
    -.globl	reset
    -.type reset, %function
    -reset:
    -	W(b)	_main
    + * Startup code (reset vector)
    +ENTRY(reset)
    +	W(b)	_main	@ Jump to _main (C runtime crt0.S)
    +ENDPROC(reset)
    -.globl	c_runtime_cpu_setup
    -c_runtime_cpu_setup:
    -	mov	pc, lr
    + * Setup CPU for C runtime
    +ENTRY(c_runtime_cpu_setup)
    +	mov pc, lr			@ Jump back to caller
    +ENDPROC(c_runtime_cpu_setup)
