All the 13.3.Rel1 Arm GNU Toolchain download links are broken:developer.arm.com/.../arm-gnu-toolchain-downloadsThey all 404 with an XML response like this one:developer.arm.com/.../arm-gnu-toolchain-13.3.rel1-mingw-w64-i686-arm-none-eabi.zip
<Error><Code>BlobNotFound</Code><Message>The specified blob does not exist. RequestId:3d1381f4-b01e-003a-341d-3a0cf7000000 Time:2024-11-19T00:51:43.4190305Z</Message></Error>
Thank you for raising this. I will investigate internally.
Thanks!In case it's useful info, as the maintainer of https://github.com/carlosperate/arm-none-eabi-gcc-action, I run a CI daily cron job to check the links are working. Yesterday at 7.30pm GMT they were fine, and the CI run today at 7.30pm GMT failed, so the problem likely arose within that 24-hour window.
Hi Carlos & Ronan,
We believe that this has now been fixed. Carlos, could you try re-downloading from the same web page/link?
Cheers,Stam
I can confirm the arm-none-eabi links are now working, thanks Stam & Ronan!
Thank you again for raising this.
