In the following functions, I count the amount of allocated memory.
Getting the alloc size fails with compiler optimization -Os balanced. The variable allocSize keeps always the init value 42. Doing the same access in 2 steps returns the correct value!
-Os balanced
And the same 1 step statement works in the osFreeMemTest() function!?
Do I have missed something in the C-syntax or is this a compiler bug?
#include <stdlib.h> static volatile uint32_t allocCount = 0; static volatile uint32_t freeCount = 0; static volatile uint32_t allocFreeDiff = 0; static volatile uint32_t allocTotal = 0; static volatile uint32_t allocTotal2 = 0; void * osAllocMemTest(size_t size) { volatile uint32_t allocSize = 42; volatile uint32_t * pAllocSize = 0; volatile uint32_t allocSize2 = 0; volatile void *p = 0; p = malloc(size); if (p == NULL) { //System reset as ultimate fault handling NVIC_SystemReset(); } allocCount++; allocFreeDiff = allocCount - freeCount; // code returns 42 with optimizing level -Os balanced, works only for -O0 and -O1 // because statement is skipped when optimized allocSize = *(((uint32_t *) p) - 1); // replacement with 2 steps works with optimization pAllocSize = ((uint32_t *) p) - 1; allocSize2 = *pAllocSize; allocTotal += allocSize; allocTotal2 += allocSize2; //Return a pointer to the newly allocated memory block return (void *) p; } /** * @brief Release a previously allocated memory block * @param[in] p Previously allocated memory block to be freed **/ void osFreeMemTest(void *p) { volatile uint32_t allocSize = 0; //Make sure the pointer is valid if(p != NULL) { freeCount++; allocFreeDiff = allocCount - freeCount; // works here with optimization -Os balanced allocSize = *(((uint32_t *) p) - 1); allocTotal -= allocSize; //Free memory block free(p); } }
