extern and __attribute__((section("xxx"))) [Arm Compiler v6]
Hi guys,
I'm having a problem with extern keyword and a variable defined in a specific memory area (section attribute).
I've defined and used in my main file the following variable:
static osThreadId_t LEDTaskID __attribute__((section("ram_shared"))) = NULL;
When I try to "include" this variable in another C file (svc_user.c) using the extern keyword, I get the following error:
.\Objects\SafetyNucleoG4.axf: Error: L6218E: Undefined symbol LEDTaskID (referred from svc_user.o).
Not enough information to list image symbols.
Not enough information to list load addresses in the image map.
I've tried to use the following code to include the variable:
extern osThreadId_t LEDTaskID;
or
extern osThreadId_t LEDTaskID __attribute__((section("ram_shared")));
But I get the same error (as reported above).
Thanks for your help,
Flavio
Ps: If I comment the code in the svc_user.c file (where the variable is used as extern), the code is compiled successfully.
