I include <atomic>
I use functions test_and_set() and clear().
Programming language C++14 and my compiler is armclang 6.18 I get the errors:
Some recommendations or suggestions?
Thank you in advance
Hello, could you provide a full source example, as well as the command line(s) used.
Also FYI, the latest version of Arm Compiler for Embedded is 6.22.
See also:
https://developer.arm.com/documentation/101754/0618/Supporting-Information-Appendix/Standard-C---Implementation-Definition/Atomic-operations-library
I don't use any special compiler or linker flags regarding the atomic library. I use it in code like this:
header file:
#include <atomic>
namespace some_namespace{class SomeClass{public: SomeClass(std::atomic_flag* ExclusiveOperation = nullptr) : exclusiveOperation(ExclusiveOperation) {} void someFunction(void);private: void anotherFunction(void); std::atomic_flag* const exclusiveOperation{nullptr};};}
cpp file that implements class functions:
#include "header_file.hpp"
namespace some_namespace{void SomeClass::someFunction(void){ if(exclusiveOperation != nullptr && exclusiveOperation->test_and_set()) {}}
void SomeClass::anotherFunction(void){ if(exclusiveOperation != nullptr)
exclusiveOperation->clear();
cpp file where class instance is created:
std::atomic_flag exclusiveOperation = ATOMIC_FLAG_INIT;SomeClass someClassInstance(&exclusiveOperation);
maybe it is related to this issue: github.com/.../73361
Hi Pavol, sorry for slow reply, I had to do some investigation.
The libatomic library is not provided, hence the link time errors.
Can you build with the compiler option -ffreestanding, to enable the compiler to generate appropriate code without relying on such a library call? I'm not sure if this is available with 6.18 of the compiler, it is only documented for 6.21 or later. The current compiler version is 6.22.
https://developer.arm.com/documentation/101754/0622/armclang-Reference/armclang-Command-line-Options/-ffreestanding
You can download the latest compiler version from the below.
https://developer.arm.com/documentation/ka005198
