I have a problem with struct compile, and I need your help. Thanks so much.
I have a register (32 bits) that is defined as a struct:
typedef struct {
int field_1 : 1;
int field_2 : 1;
int field_3 : 6;
int field_4 : 8;
int field_5 : 16;
} reg_t;
When I read/write the fileds in this struct, the compiler uses LDRB/STRB instruction. However, the register interface only supports 32b access.
How can I force the compiler to only use LDR/STR for this struct type?
