On Fedora 39, after installing ncurses-compat-libs to get libncurses5, running gdb from the ARM 13.2.Rel1 toolchain still fails, with:
$ ./arm-gnu-toolchain-13.2.Rel1-x86_64-arm-none-linux-gnueabihf/bin/arm-none-linux-gnueabihf-gdbCould not find platform independent libraries <prefix>Could not find platform dependent libraries <exec_prefix>Consider setting $PYTHONHOME to <prefix>[:<exec_prefix>]Python path configuration: PYTHONHOME = (not set) PYTHONPATH = (not set) program name = '/usr/local/bld-tools/bld-tools-virtual-env/bin/python' isolated = 0 environment = 1 user site = 1 import site = 1 sys._base_executable = '/usr/local/bld-tools/bld-tools-virtual-env/bin/python' sys.base_prefix = '/usr' sys.base_exec_prefix = '/usr' sys.executable = '/usr/local/bld-tools/bld-tools-virtual-env/bin/python' sys.prefix = '/usr' sys.exec_prefix = '/usr' sys.path = [ '/usr/lib/python38.zip', '/usr/lib/python3.8', '/usr/lib/lib-dynload', ]Fatal Python error: init_fs_encoding: failed to get the Python codec of the filesystem encodingPython runtime state: core initializedModuleNotFoundError: No module named 'encodings'Current thread 0x00007fa87ae9ec00 (most recent call first):<no Python frame>This is due to the fact that GDB is linked against Python 3.8, but Python 3.8 is not included with the toolchain. This is basically the same issue as libncurses5: the toolchain should include such dependencies.
