Crash when exporting FFT wisdom for certain c2c transform sizes
I am seeing a crash in the fftw_export_wisdom_to_filename function for certain 2d complex-to-complex transforms with FFTW_PATIENT. I've tried a range of sizes and it's rare but it appears to occur with certain larger prime sizes.
For example, 263x263 crashes, as does 269x269 and 263x269. Other nearby primes don't, though. I have not seen it for a non-prime size, but I haven't tried very hard to find failure cases.
I'm on libarmpl_lp64, version 24.04, and I've seen the same behavior on both macos and linux. I can make minimal changes to the example code in fftw_guru_dft_c2c_c_example.c to reproduce the crash:
Fullscreen
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
52,53c52,53
< const int n0 = 3;
< const int n1 = 4;
> const int n0 = 263;
> const int n1 = 269;
101,102c101,102
< fftw_plan forward = fftw_plan_guru_dft(RANK, dims, HM_RANK, hm_dims, x, y, FFTW_FORWARD, FFTW_ESTIMATE);
< fftw_plan backward = fftw_plan_guru_dft(RANK, dims, HM_RANK, hm_dims, y, x, FFTW_BACKWARD, FFTW_ESTIMATE);
> fftw_plan forward = fftw_plan_guru_dft(RANK, dims, HM_RANK, hm_dims, x, y, FFTW_FORWARD, FFTW_PATIENT);
> fftw_plan backward = fftw_plan_guru_dft(RANK, dims, HM_RANK, hm_dims, y, x, FFTW_BACKWARD, FFTW_PATIENT);
127a128,131
> if (!fftw_export_wisdom_to_filename("test.fftwisdom")) {
> fprintf(stderr, "export error\n");
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
The crash occurs with FFTW_PATIENT or FFTW_MEASURE but not FFTW_ESTIMATE.
I am observing no real loss in performance when changing to FFTW_ESTIMATE, so this is an acceptable workaround for me. That leads me to a related question: should I expect any advantage to the MEASURE or PATIENT planner modes in armpl?
0
