Hi Community,In the Semiconductor's Code Example, still in Init Process (set struct variables with init values), running is face the code line and stopped (I can break only after that)
/* polyspace +3 MISRA2012:10.1 [Justified:Low] "Bitwise operators on signed values are required by fixed point
* arithmetic." */
samplingTimeQ30 = (Ifx_Math_Fract32)( ( ((sint64)self->p_samplingTime_us) << (sint8)Ifx_Math_FractQFormat_q30/*30*/ ) / IFX_MATH_MICROSECONDS_TO_SECONDS/*1000000*/ ); // stopped hereThe running can not run over this line:
The compiler, build, flash to Eval Board are OK:I use µVision 5, MDK537 (compiler V6.18) or MDK538a(compiler V6.19)Thanks for your comments!Best Regards,
TV
