I am seeing the below errors when I try to compile my code in Arm Compiler 6. Can you please help me to resolve this issue?
error: invalid operand for instruction MRS r0, PSP
error: invalid operand for instruction MRS r0, MSP
Environment are below:
CORE = cortex-m4FPU = fpv4-sp-d16ARCH = armv7-a
Pradeep
Cortex-M4 is an Architecture Armv7-M (not Armv7-A). Can you confirm the command line used?
Ronan
Hi Ronan,
Below is the command.
armclang -c --target=arm-arm-none-eabi -march=armv7-a -mfpu=fpv4-sp-d16 -marm -masm=auto -I include -o obj/startup_cm4.o startup_cm4.S
You must change the -march option to -march=armv7-m.
Also, remove -marm.
I dont think the -mfpu option you have is valid either.
Below error is observed when I changed the architecture to armv7-m. Can you please point out what could be the issue?
armclang -c --target=arm-arm-none-eabi -march=armv7-m -mfpu=fpv4-sp-d16 -marm -masm=auto -I include -o obj/startup_cm4.o startup_cm4.S
armclang: error: Architecture 'armv7-m' does not support 'ARM' execution modearmclang: error: Architecture 'armv7-m' does not support 'ARM' execution mode
Okay.. Now I see the below error.
armclang -c --target=arm-arm-none-eabi -march=armv7-m -mfpu=fpv4-sp-d16 -masm=auto -I include -o obj/startup_cm4.o startup_cm4.S
startup_cm4.S:152:13: error: invalid operand for instruction MSR CPSR, r0.
Issue is resolved.
Hi Ronan
I need some help converting linker file(LD) into scatter file. Attached the linker file. I need some input to convert into scatter file.
/* __DISCLAIMER_START__ */ /****************************************************************************** * (c) 2014-2017, Cypress Semiconductor Corporation * or a subsidiary of Cypress Semiconductor Corporation. All rights * reserved. * * This software, including source code, documentation and related * materials ( "Software" ), is owned by Cypress Semiconductor * Corporation or one of its subsidiaries ( "Cypress" ) and is protected by * and subject to worldwide patent protection (United States and foreign), * United States copyright laws and international treaty provisions. * Therefore, you may use this Software only as provided in the license * agreement accompanying the software package from which you * obtained this Software ( "EULA" ). * * If no EULA applies, Cypress hereby grants you a personal, nonexclusive, * non-transferable license to copy, modify, and compile the * Software source code solely for use in connection with Cypress' s * integrated circuit products. Any reproduction, modification, translation, * compilation, or representation of this Software except as specified * above is prohibited without the express written permission of Cypress. * * Disclaimer: THIS SOFTWARE IS PROVIDED AS-IS, WITH NO * WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING, * BUT NOT LIMITED TO, NONINFRINGEMENT, IMPLIED * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A * PARTICULAR PURPOSE. Cypress reserves the right to make * changes to the Software without notice. Cypress does not assume any * liability arising out of the application or use of the Software or any * product or circuit described in the Software. Cypress does not * authorize its products for use in any products where a malfunction or * failure of the Cypress product may reasonably be expected to result in * significant property damage, injury or death ( "High Risk Product" ). By * including Cypress' s product in a High Risk Product, the manufacturer * of such system or application assumes all risk of such use and in doing * so agrees to indemnify Cypress against all liability. ******************************************************************************/ /* __DISCLAIMER_END__ */ /*****************************************************************************/ /* !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! This linker file needs to be preprocessed by GCC because LD does not support preprocessing. CMake build environment will take care of this! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!*/ /* Check that necessary definitions are available */ #if (!defined(_LINK_flash_)) && (!defined(_LINK_sram_)) #error "Link location not defined or not supported!" #endif #if (!defined(_CORE_cm0plus_)) && (!defined(_CORE_cm4_)) #error "Target core not defined or not supported!" #endif #if (!defined(CY_MCU_rev_a)) && (!defined(CY_MCU_rev_b)) && (!defined(CY_MCU_rev_c)) && (!defined(CY_MCU_rev_d)) #error "MCU revision is not defined or not supported!" #endif /*======================================================================================= // Description of special symbols //======================================================================================= // sram_private_for_srom: // The SROM code needs an area for private data during system call processing. It will // not be accessible by user software in protection state NORMAL and beyond. // So it needs to be excluded from the total SRAM available to the user. The location of // this RAM depends on the MCU revision. // // sram_used_by_boot_base: // Cypress (ROM and Flash) boot firmware needs an area in SRAM (e.g. for stack). This may cause issues in case of // RAM build configurations when code/const sections are loaded there by the debugger, but may get overwritten // if reset is triggered by the debug script later on. So in case of RAM build configurations the linker should // check if the area of ROM type sections overlaps the boot area. // // sram_can_lin_boot_reserve: // Cypress CAN/LIN Bootloader is entered only if several conditions apply (refer Architecture TRM, "Flash Boot" chapter). // It will then use an area of SRAM for its data. // This may cause issues in case of RAM build configurations when code/const sections are loaded there by the debugger, // but may get overwritten if reset is triggered by the debug script later on. Therefore, this area shall be reserved. // // ecc_init_width: // Defines the most restrictive native ECC width (in bytes) of all "normal" memories (SRAM, DTCM, ITCM) in any // Traveo II derivate in order to keep the startup code dealing with ECC initialization generic */ /*======================================================================================= // Following symbol and memory area definitions are device specific //=======================================================================================*/ /* Constants */ #define code_flash_total_size 1088K #define sram_total_size 128K #define sram_base 0x08000000 #define sram_used_by_boot_base (sram_base + sram_total_size - 6K) #define sram_private_for_srom 2K #define cm0plus_intvec_alignment 256 /* CPU specific vector table alignment requirement */ #define cm4_intvec_alignment 1024 /* CPU specific vector table alignment requirement */ #define ecc_init_width 8 #if defined(_LINK_sram_) #define sram_can_lin_boot_reserve 512 #else #define sram_can_lin_boot_reserve 0 #endif #if defined(CY_MCU_rev_a) || defined(CY_MCU_rev_b) || defined(CY_MCU_rev_c) #define sram_user_start_offset (0 + sram_can_lin_boot_reserve) #define sram_user_end_offset (sram_total_size - sram_private_for_srom) #else #define sram_user_start_offset (sram_private_for_srom + sram_can_lin_boot_reserve) #define sram_user_end_offset (sram_total_size - 0) #endif /*=================================================================================== // USER CONFIGURATION //===================================================================================*/ /* Specify how much SRAM and CODE_FLASH shall be used by CM0+ application, * the rest of the memory will be automatically assigned to CM4 application */ #define cm0plus_sram_reserve (64K - sram_user_start_offset) #define cm0plus_code_flash_reserve 512K /*-----------------------------------------------------------------------------------*/ /* Specify stack and heap sizes for CM0+ and CM4 application independently */ #define cm0plus_heap_reserve 512 #define cm0plus_stack_reserve 1K #define cm4_heap_reserve 512 #define cm4_stack_reserve 1K /*===================================================================================*/ /* Calculation of SRAM distribution among all cores */ #define cm0plus_sram_offset sram_user_start_offset #define cm4_sram_offset (cm0plus_sram_offset + cm0plus_sram_reserve) #define cm4_sram_reserve (sram_user_end_offset - cm4_sram_offset) /* Calculation of CODE_FLASH distribution among all cores */ #define cm0plus_code_flash_offset 0 #define cm4_code_flash_offset (cm0plus_code_flash_offset + cm0plus_code_flash_reserve) #define cm4_code_flash_reserve (code_flash_total_size - cm4_code_flash_offset) /* Map core dependent definition to generic name for memory and section definition */ #if defined(_CORE_cm0plus_) #define heap_reserve cm0plus_heap_reserve #define stack_reserve (cm0plus_stack_reserve + (ecc_init_width - 1)) & (~((ecc_init_width - 1))) /* Ensure that stack size is an integer multiple of ECC init width (round up) */ #define sram_offset cm0plus_sram_offset #define sram_reserve cm0plus_sram_reserve #define code_flash_offset cm0plus_code_flash_offset #define code_flash_reserve cm0plus_code_flash_reserve #define intvec_alignment cm0plus_intvec_alignment #else /* CM4 */ #define heap_reserve cm4_heap_reserve #define stack_reserve (cm4_stack_reserve + (ecc_init_width - 1)) & (~((ecc_init_width - 1))) /* Ensure that stack size is an integer multiple of ECC init width (round up) */ #define sram_offset cm4_sram_offset #define sram_reserve cm4_sram_reserve #define code_flash_offset cm4_code_flash_offset #define code_flash_reserve cm4_code_flash_reserve #define intvec_alignment cm4_intvec_alignment #endif MEMORY { SRAM (rwx) : ORIGIN = sram_base + sram_offset, LENGTH = sram_reserve CODE_FLASH (rx) : ORIGIN = 0x10000000 + code_flash_offset, LENGTH = code_flash_reserve WORK_FLASH : ORIGIN = 0x14000000, LENGTH = 0x00018000 /* 96 KB */ SFLASH : ORIGIN = 0x17000000, LENGTH = 0x00008000 /* 32 KB */ SFLASH_ALT : ORIGIN = 0x17800000, LENGTH = 0x00008000 /* 32 KB */ } /*======================================================================================= // // Program layout */ SECTIONS { /*============================================================================================================ // ROM type sections //------------------------------------------------------------------------------------------------------------*/ #if defined(_LINK_flash_) #define MEMORY_FOR_ROM_TYPE_SECTIONS CODE_FLASH #elif defined(_LINK_sram_) #define MEMORY_FOR_ROM_TYPE_SECTIONS SRAM #endif /* Note: .intvec must be the first section in ROM in order for __cmx_vector_base_linker_symbol to be correctly calculated! */ .intvec : ALIGN(intvec_alignment) { *(.intvec) } >MEMORY_FOR_ROM_TYPE_SECTIONS .text : ALIGN(4) { *(.text*) } >MEMORY_FOR_ROM_TYPE_SECTIONS .rodata : ALIGN(4) { *(.rodata*) } >MEMORY_FOR_ROM_TYPE_SECTIONS /* Special GCC ARM sections */ .ARM.extab : ALIGN(4) { *(.ARM.extab* .gnu.linkonce.armextab.*) } > MEMORY_FOR_ROM_TYPE_SECTIONS .ARM.exidx : ALIGN(4) { *(.ARM.exidx* .gnu.linkonce.armexidx.*) } > MEMORY_FOR_ROM_TYPE_SECTIONS /*============================================================================================================ // RAM type sections //------------------------------------------------------------------------------------------------------------*/ /* >>> SRAM <<< */ /* In case of _LINK_sram_ the linker (LD) would set the LMA of '.data' to its VMA (because both end up in the same memory region). * Therefore, the '.data' section needs to be the first one of the "RAM type" sections so that the '__rom_type_sections_end_address' * can be correctly calculated and startup code will not ECC initialize the RAM area occupied by the .data section (since its content * would have been loaded by the debugger already). In case of _LINK_flash the '.data' section can be arbitrarily placed in RAM. */ .data : ALIGN_WITH_INPUT { . = ALIGN(ecc_init_width); *(.data*) . = ALIGN(ecc_init_width); } >SRAM AT>MEMORY_FOR_ROM_TYPE_SECTIONS .bss (NOLOAD) : ALIGN(ecc_init_width) { *(.bss*) *(COMMON) . = ALIGN(ecc_init_width); } >SRAM .heap (NOLOAD) : ALIGN(8) { __heap_start = .; . += ALIGN(heap_reserve, 8); __heap_end = .; } >SRAM .stack (NOLOAD) : ALIGN(8) { __stack_start = .; . += ALIGN(stack_reserve, 8); __stack_end = .; } >SRAM .intvec_ram (NOLOAD) : ALIGN(intvec_alignment) { *(.intvec_ram) } >SRAM /* Linker symbols for startup code */ __data_lma = LOADADDR(.data); __data_start = ADDR(.data); __data_end = ADDR(.data) + SIZEOF(.data); __bss_start = ADDR(.bss); __bss_end = ADDR(.bss) + SIZEOF(.bss); #if defined(_LINK_sram_) /* Cypress (ROM and Flash) boot firmware needs an area in SRAM (e.g. for stack). This may cause issues in case of * RAM build configurations when code/const sections are loaded there by the debugger, but may get overwritten * if reset is triggered by the debug script later on. So in case of RAM build configurations the following * statement checks if the area of ROM type sections overlaps the boot area. * Comment the statement if the sections shall be linked there anyway. * * A simple check is sufficient because the boot area is from SRAM_MAX-6KB to SRAM_MAX-2KB and it is unlikely that the ROM sections would only * start in the last 2KB (which are anyway not accessible in early MCU revisions because of private SROM RAM area) */ __rom_type_sections_end_address = __data_end; ASSERT(__rom_type_sections_end_address < sram_used_by_boot_base, "ROM type sections are overlapping the area used by Cypress boot firmware. Check comment in linker file!") #endif /*============================================================================================================ // The start of CM4 vector table is required by CM0+ application to correctly // set CPUSS->CM4_VECTOR_TABLE_BASE register before releasing CM4 from reset // Following statements also ensure that the created symbol has the correct alignment //------------------------------------------------------------------------------------------------------------*/ #ifdef _CORE_cm0plus_ #if defined(_LINK_flash_) __cm4_rom_start = ORIGIN(CODE_FLASH) - cm0plus_code_flash_offset + cm4_code_flash_offset; #elif defined(_LINK_sram_) __cm4_rom_start = ORIGIN(SRAM) - cm0plus_sram_offset + cm4_sram_offset; #endif __cm4_vector_base_linker_symbol = (__cm4_rom_start + cm4_intvec_alignment - 1) & ~(cm4_intvec_alignment - 1); #endif /*============================================================================================================ // These symbols will be used by startup.c / startup_customize.h for RAM ECC initialisation //------------------------------------------------------------------------------------------------------------*/ #if defined(_LINK_sram_) /* If "ROM type" sections are linked to SRAM they shall not be cleared by the startup code */ __ecc_init_sram_start_address = __rom_type_sections_end_address; /* The __rom_type_sections_end_address symbol is a marker for the start of "RAM type" sections in SRAM */ #else __ecc_init_sram_start_address = ORIGIN(SRAM); #endif __ecc_init_sram_end_address = ORIGIN(SRAM) + LENGTH(SRAM) - 1; /*============================================================================================================ // These special symbols mark the bounds of RAM and ROM memory. // They are used by the GHS MULTI debugger. //------------------------------------------------------------------------------------------------------------*/ /* __ghs_romstart = ORIGIN(CODE_FLASH); __ghs_romend = ORIGIN(SFLASH_ALT) + LENGTH(SFLASH_ALT); __ghs_ramstart = ORIGIN(SRAM); __ghs_ramend = ORIGIN(SRAM) + LENGTH(SRAM); */ }
Does this help?https://community.arm.com/arm-community-blogs/b/tools-software-ides-blog/posts/migrate-to-arm-compiler-6-from-gcc
I am seeing the below errors during linking. Can you help me to resolve the issue?
Warning: L6340W: options first and last are ignored for link type of scatteredError: L6218E: Undefined symbol __ecc_init_sram_end_address (referred from startup.o).Error: L6218E: Undefined symbol __ecc_init_sram_start_address (referred from startup.o).Error: L6218E: Undefined symbol __bss_end (referred from startup_cm4.o).Error: L6218E: Undefined symbol __bss_start (referred from startup_cm4.o).Error: L6218E: Undefined symbol __data_end (referred from startup_cm4.o).Error: L6218E: Undefined symbol __data_lma (referred from startup_cm4.o).Error: L6218E: Undefined symbol __data_start (referred from startup_cm4.o).Error: L6218E: Undefined symbol __stack_end (referred from startup_cm4.o).
Those symbols are defined in the linker script.
You would need to #define them to match the equivalent symbols generated by scatterloading, such as:
#define _bss_start Image$$ZI_REGION$$Base
Where ZI_REGION is the name given to the execution region in your scatter file.
