I have a question regarding declaring a variable as volatile. If the memory region is configured as cacheable by configuring the MPU and if the variable is declared as volatile, will it be cached ? If any reads from the core will result in direct main memory read always, though the region is cached ?
Hello
The compiler would have no knowledge of what memory regions are cacheable. If it is placed in a cacheable region, then yes, it will be cached.
Use scatter loading, and/or attribute settings to locate such a variable appropriately.
See https://developer.arm.com/documentation/101754/0620/armlink-Reference/Scatter-loading-Features/Root-region-and-the-initial-entry-point/Methods-of-placing-functions-and-data-at-specific-addresses/Placing-a-variable-at-a-specific-address-without-scatter-loading
