I've got some code that was originally written for the LPC1768 which I am trying to "back-port" to the LPC2388
Most of that exercise was dealing with name changes, and was a (fairly) simple editing job.
Now however I have some code that reads:
// Reset Timer 2 T2TCR = 0x02; T2TCR = 0x00; // Timer mode, increment on PCLK // Calculate the match value based on the desired milliseconds delay uint32_t matchValue = (uint32_t)(((SystemCoreClock/1000) * millis) - 1); matchValue -= 50; // Allow for the code in this function plus calling it T2MR0 = matchValue; // Set the match value
As you can see most of it has been converted already (e.g. LPC_TIM2->TCR became T2TCR).How can I access the current clock speed value for the LPC2388 given that SystemCoreClock isn't defined anywhere in the 2388 headers etc..
Thanks, David
