How to isolate MVE Library and functions in MDK with Arm compiler 6.19?
I am using Arm compiler(AC6.19) with MDK 5.38 and Cortex M85(CM85) chip. As we know that MDK5.38 can set the CM85 Vector Extensions (MVE) setting as below to enable Marco "ARM_MATH_HELIUM", "ARM_MATH_MVEF". "ARM_MATH_MVEI". This setting impacts ARM CMSIS DSP library.
  1.  When i am writing myself code, how to prevent MDK to generate my code in MVE enable style, my target is that i don't want MDK to optimize my code in MVE style. such as helium assemble code, SIMD code or auto-vectorization. How to do this with MDK?
  2. I have a compiled library with DSP function with MVE disabled. My application code wants MVE enable. How can i do this----"Compile a program that application code with MVE enable and a library with MVE disable together?" It is similar the library MVE isolation.How to do this with MDK?
0
