Error L6244E generated by ARMLINK after switching from ARMCC to ARMCLANG.
Currently, I'm working on the transition of a project initially compiled with ARMCC (for an ARMv7 architecture) and now compiled with ARMCLANG (for an ARMv8 architecture).
With ARMLINK, I get the following error:
Error: L6244E: Load region LOAD_TTB address (0x0000f800) not aligned on a 16384 byte boundary.
Below is the scatter file sample:
LOAD_TTB 0xF800 0x4800
  CODE_TTB AlignExpr(+0, 0x4800)
    ttb.o (+RO)
I haven't found any information (especially in the links below) on why this error occurs now and if this error is a source of faults when running a program. Or I can safely use “--diag_suppress=6244”.
Do you have a rough explanation to help me to understand, Why switching to ARMCLANG generates this error with ARMLINK?
In addition, can you highlight a related documentation?
Thanks in advance.
Arm Compiler for Embedded Errors and Warnings Reference Guide: https://developer.arm.com/documentation/100074/latest/
Arm Compiler armlink User Guide: https://developer.arm.com/documentation/dui0803/l/?lang=en
https://community.arm.com/support-forums/f/compilers-and-libraries-forum/54501/error-l6244e-region-not-aligned-on-cm33-secure-world-with-arm-v6-19-compiler
  • Hello,
    0x4800 is not a valid AlignExpr() value, it must be a power of 2. Hence the error message refers to 16384 (0x4000), which is 0x4800 rounded down to nearest 2^n.
    https://developer.arm.com/documentation/101754/0620/armlink-Reference/Scatter-File-Syntax/Expression-evaluation-in-scatter-files/AlignExpr-expr--align--function
    The linker error presumably is then incurred as it cannot place your CODE_TTB execution region in a valid location within these parameters. How big is the code within ttb.o? (use "fromelf -z ttb.o").
    Regards, Ronan
  • Hello,
    Thank you for your reply.
    In a file ttb.c, three tables are declared with the following attribute “__attribute__((at(0xFC00)))” (Originally compiled with ARMCC). Following the documentation “Migration and Compatibility Guide“, I changed the attribute to “__attribute__((section(".ARM.__at_0xFC00")))“.
    I then noticed that ARMLINK had added a PADDING zone in LOAD_TTB in place of one of the arrays with the attribute “__attribute__((section(".ARM.__at_0xFC00")))“. So I added "AlignExpr()" as suggested in the ARMLINK documentation « 8.12 Example of using expression evaluation in a scatter file to avoid padding »
    If AlignExpr() is undesirable in my case, I have two questions:
    1. Why does ARMLINK add a PAD section, knowing that this was not the case when the code was compiled with ARMCC?
    2. How can I avoid introducing a padding section?
    Extract from the memory map provided by ARMLINK:
      Load Region LOAD_TTB (Base: 0x0000f800, Size: 0x00004800, Max: 0x00004800, ABSOLUTE)
        Execution Region CODE_TTB (Base: 0x0000f800, Size: 0x00004800, Max: 0x00004800, ABSOLUTE)
        Base Addr    Size         Type   Attr      Idx    E Section Name        Object
        0x0000f800   0x00000400   Data   RO          134    .ARM.__at_0xF800    ttb.o
        0x0000fc00   0x00000400   PAD
        0x00010000   0x00004000   Data   RO          132    .ARM.__at_0x10000   ttb.o
      Load Region LR$$.ARM.__at_0xF800 (Base: 0x0000f800, Size: 0x00000000, Max: 0x00000400, ABSOLUTE)
        Execution Region ER$$.ARM.__at_0xF800 (Base: 0x0000f800, Size: 0x00000000, Max: 0x00000400, ABSOLUTE, UNINIT)
        **** No section assigned to this execution region ****
      Load Region LR$$.ARM.__at_0xFC00 (Base: 0x0000fc00, Size: 0x00000400, Max: 0x00000400, ABSOLUTE)
        Execution Region ER$$.ARM.__at_0xFC00 (Base: 0x0000fc00, Size: 0x00000400, Max: 0x00000400, ABSOLUTE, UNINIT)
        0x0000fc00   0x00000400   Data   RO          133    .ARM.__at_0xFC00    ttb.o
    To answer your question:
    $ fromelf -z ttb.o
    ** Object/Image Component Sizes
    Code (inc. data) RO Data RW Data ZI Data Debug Object Name
    0                      0      18432            0           0      700               ttb.o
    Regards,
  • Could you share your ttb.c source code? It may be best to raise an 'official' support case from the support menu above, so that it can be shared privately to Arm (please reference this thread).
    I don't understand what is happening, based on your description above.
