We have a small fleet of DS-5/Development Studio projects that target Cyclone V and we're interested in building these projects in containers. Some questions:
I believe the Intel Edition of Development Studio is node-locked only. The functionality is a subset of the Development Studio Silver Edition.
To build existing projects from the command line, see the below:https://developer.arm.com/documentation/101469/2022-2/Projects-and-examples-in-Arm-Development-Studio/Working-with-projects/Run-the-Arm-Development-Studio-IDE-from-the-command-line-to-clean--build--and-import-projects
I'm not aware of a Docker image that contains the IDE. By their nature, they tend to be CLI tool only. If you are looking to set up an automated build, you may wish to move to a makefile or CMake based infrastructure.
Perhaps you could share more detail on your end goal? Feel free to send me a DM if you prefer to discuss in non-public forum. (I am a Solutions Architect at Arm).
Regards, Ronan
AFAIK the next 4 steps for us are:
I'm a DevOps engineer that's relatively new to embedded systems so I don't know what #4 looks like yet.
There are a couple of solutions for #4 that we offer.
Fixed Virtual Platforms (FVPs): These are available 'standalone', or as part of the (full) Arm Development Studio.https://developer.arm.com/Tools%20and%20Software/Fixed%20Virtual%20Platforms
A most advanced use case would be to license Arm Fast Models technology to be able to create your own FVP closer to your real hardware.https://developer.arm.com/Tools%20and%20Software/Fast%20Models
Arm Virtual Hardware: Cloud based virtual platforms (both FVP-based and a new technology more suitable for complex Cortex-A systems):https://www.arm.com/products/development-tools/simulation/virtual-hardware
I'm quite stuck on #1 ATM. There a couple constraints I'm working in right now: 1. Must build from Windows and 2. Must build using eclipse/armds_idec. I think we will eventually have to move away from this model as the Windows containers are HUGE and slow, and the full IDE installation seems excessive.
I performed a silent install of ARM DS Intel Edition (at the dev's request) per https://developer.arm.com/documentation/ka004603/latest in a Windows Server Core image and it the installation appears to have completed successfully. However, when I try to start the environment via cmdsuite.exe I get some odd errors:
C:\Program Files\Arm\Development Studio 2022.2\bin>cmdsuite.exe wrapper: Failed to query My Documents directory in registry with error 2cmdsuite.exe wrapper: Could not read environment file C:\Program Files\Arm\Development Studio 2022.2\sw\info\env.ini: Operation not permitted wrapper: Failed to query My Documents directory in registry with error 2Environment configured for Arm Development Studio (build 202220912) Please consult the documentation for available commands and more details WARNING: No compiler toolchain specified for environment You can change the compiler toolchain for this environment at any time by running the 'select_toolchain' command. A default for all future environments can be set with the 'select_default_toolchain' command.
The Server Core image isn't a "complete" Windows API, so there may be something missing here that cmdsuite/armds_idec needs to function properly.
I've never experienced this error before.
I found the below thread (from our older DS-5 toolchain, but the tools share a common ancestry) which may help?https://community.arm.com/support-forums/f/armds-forum/46095/ds-5-eclipse-cannot-read-environment-file-env-ini
That does sound like it would do the trick, but due to the resulting image size/speed we ended up starting with an Ubuntu image and installing ARMDS and a specific version of the ARM compiler requested by the developers and that seems to be working well.
Unfortunately, they appear to have been using a customized version of mkimage in the post-build step that was only built as a Windows exe years ago. I had installed the latest u-boot-tools apt package, but that was apparently generating an img file that had a checksum that didn't match prior builds of the same source.
I was surprised (being new to ES) to find this article: https://www.rocketboards.org/foswiki/Documentation/BuildingBootloaderCycloneVAndArria10 where the instructions have you build u-boot from source.
