In a map file generated by armclang I see this summary:
============================================================================== Code (inc. data) RO Data RW Data ZI Data Debug 31116 1464 3668 24 43056 10172 Grand Totals 31116 1464 3668 24 43056 10172 ELF Image Totals 31116 1464 3668 24 0 0 ROM Totals ==============================================================================
This is for a 'Release' build. What does the 'Debug' column depict here?
Hi David,
This seems to be some rogue(?) header information from the objects. Adding the linker option --nodebug forces its removal.
Note this is 'just' debug information... it does not affect the code size of the image.
Hi Ronan
Thanks for your answer.
Best regards
David
