How to force a static library at a specific memory address
I am building some applications that use a static library and I would want to force linker to put .text and .data sections of the static library (.a file) at specific addresses using GNU linker (arm-none-eabi-gcc) but I couldn't find a way how the linker script can be modified to force/put the libx.a at a specific address considering that this library has .text and .data sections.
Is there any way to do it?
I tried the below but linker does nothing:
    .text_libx :
        . = ALIGN(4);
        KEEP(libx.a(.text .text.*))
     } >FLASH_libx
where FLASH_libx is defined to a desired address.
0
