Hi :)
I am a newbie in handling A5, and want to verify the operation of A5.
I am validating the RTL of ARM Cortex A5, CORTEXA5MP_vectors.
But, when I Orderd the command "make caputure", got message "armasm : command not found".
Through the content of the Arm developer community, I learned that I should get Realview.
<[Link] community.arm.com/.../armasm-command-not-found>
However, I installed Realview, but armams return message "need license file".(The exact message is "Cannot obtain license for Assembler")
To sum up, armasm doesn't work for A5 validating.
So ask for a solution. Specifically, I would like to ask the following questions:
1-1. I purchased Cortex-A5_MPCore_with_Neon_FPU_ETM, so is it possible to validate within the package configuration?
1-2. Or is there a demo that temporarily operates Realview?
2-1. In the Arm Developer Community, Realview is outdated and recommends Arm Development Studio. Is it possible to validate A5 with Arm Development Studio instead of armasm?
2-2. Or My team using Keil Compiler, Is it possible to validate A5 with Keil Compiler instead of armasm?
I need your Support, Thank you!
Sincerely
Ki Yul Ko(Fishten)
PS. I wrote the progress in the attached presentation file.
Question diary(20221228)_en.pptx
<[Link] Arm Developer Community - armams command not found>
https://community.arm.com/support-forums/f/architectures-and-processors-forum/49505/armasm-command-not-found
Hi Fishten,
My name is Christian and I work here at Arm.
We do not issue licenses for RealView as it is an unsupported product at this point.
You can build the testbenches for Cortex-A5 using Arm DS. However, please note the following:
Hopefully, this is helpful. :)
