Are there any interpolation examples in CMSIS DSP library using cubic spline?
I have a simple waveform where x is the time stamp and y is the sine wave, I can use use MATLAB to plot the
sine wave correctly. I am pretty confident that I parse the same raw data into X and Y data buffer correctly as meas_X and meas_Y.
float outX[2*SAMPLE_LENGTH];
float outY[2*SAMPLE_LENGTH];
float outbuf[2*SAMPLE_LENGTH-1];
float coef[3*(SAMPLE_LENGTH-1)];
arm_spline_instance_f32 S;
arm_spline_init_f32(&S, ARM_SPLINE_PARABOLIC_RUNOUT, meas_X, meas_Y, SAMPLE_LENGTH, coef, outbuf); arm_spline_f32(&S, outX, outY, 4);
The outY is always a flat line. Are there any known issues in arm_spline_f32() or something I should be aware of?
Thanks,
Tom
It's a user error. I think I know the problem. I didn't have correct outX (xq) value, the points to the x values or the interpolated data points.
Thank you for coming back and sharing the solution you found :)
