What is the equivalent of GCC's -backtrace with ACFL?
I am trying to use Arm Compiler for Linux (version 22.1.0) instead of GCC (version 11.2.0) and I struggle to find the equivalent of GCC's compiler options, in particular -fbacktrace (but also -fcheck=bounds -ffpe-trap=invalid,zero,overflow, etc.)
Do such options exist?
  • Hi Jeani
    I'll answer each option in turn as the answer is slightly different for all.
    -fbacktrace - armflang behaves in the same way as gfortran -fno-backtrace. There is no support for the equivalent of -fbacktrace behaviour in armflang.
    -Mbounds armflang does not officially support this functionality, but there is the undocumented, community supported option -M[no]bounds, which toggles this functionality so you can give this a try to see if it works for you. We have no plans to officially support this option.
    -ffpe-trap - armflang does not support this fine-grained control of FP exception traps. There is the supported option -f[no]-trapping-math to enable/disable them all together
    Ta
    Rich
  • Thank you for your answers Rich, I will give it a try
