Hello.
I'm trying to use arm-none-eabi-gcc (with several versions such as 10.3-2021.10) on windows to compile a dynamic library for ARM Cortex-M33; If I use compile option with -mcpu=cortex-m33, the build fails with an error "warning: thumb-1 mode PLT generation not currently supported collect2.exe: error: ld returned 1 exit status。".
Here is an example of my compile and result:
arm-none-eabi-gcc.exe -fPIC -mthumb -mcpu=cortex-m33 -mfloat-abi=hard -mfpu=fpv5-sp-d16 -fPIC -shared -nostdlib -nostartfiles -fdata-sections -ffunction-sections -Og -g0 -o libexternal_qrcode.so
The result:
arm-none-eabi/bin/ld.exe: libexternal_qrcode.so: warning: thumb-1 mode PLT generation not currently supported collect2.exe: error: ld returned 1 exit status。
however, if I change compile option to -mcpu=cortex-m4, the buid succeeds.
Hi!
Which version of the GNU binutils do you use?
Tried a simple example with your mentioned compiler/linker arguments for Cortex-M33 and works fine (no errors) with the actually version of GNU-ld and GCC:
$ arm-none-eabi-gcc -fPIC -mthumb -mcpu=cortex-m33 -mfloat-abi=hard -mfpu=fpv5-sp-d16 -fPIC -shared -nostdlib -nostartfiles -fdata-sections -ffunction-sections -Og -g0 -o libfoo.so foo.c $
Content of foo.c:
int foo(int a, int b) { return a + b; }
GNU-ld version:
$ arm-none-eabi-ld --version GNU ld (GNU Binutils) 2.39.50.20221031 Copyright (C) 2022 Free Software Foundation, Inc. This program is free software; you may redistribute it under the terms of the GNU General Public License version 3 or (at your option) a later version. This program has absolutely no warranty. $
GCC version:
$ arm-none-eabi-gcc --version arm-none-eabi-gcc (GCC) 12.2.1 20221104 Copyright (C) 2022 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Hi
Here is my GNU binutils version:
$ arm-none-eabi-gcc --versionarm-none-eabi-gcc.exe (GNU Arm Embedded Toolchain 10.3-2021.10) 10.3.1 20210824 (release)Copyright (C) 2020 Free Software Foundation, Inc.This is free software; see the source for copying conditions. There is NOwarranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Where could I download the 2022 version GNU? The lateset version in this website(developer.arm.com/.../gnu-rm) is 2021.10
Sorry, I just noticed this site has been deprecated. Thans for your answer.
