Dear developer collegues,
I have the follwing linker script snippet:
/* Memories definition */MEMORY{ DTCMRAM (xrw) : ORIGIN = 0x20000000, LENGTH = 128K ITCMRAM (xrw) : ORIGIN = 0x00000000, LENGTH = 64K RAM_D1 (xrw) : ORIGIN = 0x24000000, LENGTH = 320K RAM_D2 (xrw) : ORIGIN = 0x30000000, LENGTH = 32K RAM_D3 (xrw) : ORIGIN = 0x38000000, LENGTH = 16K - 0x200 RAM_COMMAND(xrw) : ORIGIN = 0x38003E00, LENGTH = 0x200 FLASH (rx) : ORIGIN = FLASH_ORIGIN, LENGTH = FLASH_LENGTH FLASH_EXT (rx) : ORIGIN = EXTERN_FLASH_ORIGIN, LENGTH = EXTERN_FLASH_LENGTH}
/* Sections */SECTIONS{ /* The startup code into "FLASH" Rom type memory */ .isr_vector : { . = ALIGN(4); KEEP(*(.isr_vector)) /* Startup code */ . = ALIGN(4); } >FLASH .bootstrapping_code : { . = ALIGN(4); *generated/*.obj (.text .text*) *hw/*.o (.text .text*) *startup/*.o (.text .text*) . = ALIGN(4); } >FLASH
/* The program code and other data into "FLASH" Rom type memory */ .text : { . = ALIGN(4); *(.text) /* .text sections (code) */ *(.text*) /* .text* sections (code) */ *(.glue_7) /* glue arm to thumb code */ *(.glue_7t) /* glue thumb to arm code */ *(.eh_frame)
KEEP (*(.init)) KEEP (*(.fini))
. = ALIGN(4); _etext = .; /* define a global symbols at end of code */ } >FLASH_EXT
The goal is to have the code splitted into external (qspi-flash) and internal flash. The script is working fine, at least according to the generated elf...
But, if not all sections are directed to the same flash, the linker takes around 5mins to link. With all sections in the same flash, linking time is 1sec.
Does anybody have an idea how to debug this?
Thank you,
Simon
