I'm just learning assembly code, trying to do the following, but it doesn't work. Why? Thanks.
register uint32 c[] = { 0, 0, 0, 0 }; register uint32 a[] = { 2, 5, 7, 9 }; register uint32 b[] = { 3, 3, 4, 5 }; __asm__ __volatile__( "ADD %0.2d, %1.2d, %2.2d;" : "=w" (c) // output : "w" (a) // input , "w" (b) // input ); for(auto i = 0; i < (sizeof(c)/sizeof(c[0])); ++i) { printf("%s a(%d) + b(%d) = c(%d)\n", __FUNCTION__, a[i], b[i], c[i]); //TODO: remove all printf's }
Moved to the Compilers forum
Hello, what are you expecting?
I made an example file based on your source. and got the following error, which is due to the 'register' qualifier, forcing the arrays to be stored in internal registers.
> error: address of register variable requested
Regards, Ronan
