I am compiling a C++ arm-none-eabi project and getting following error, using the ARM GNU Toolchain V12.2.bet1.
[build] In file included from c:\...\arm-gnu-toolchain-12.2.mpacbti-bet1-mingw-w64-i686-arm-none-eabi\arm-none-eabi\include\c++\12.2.0\string:41, [build] from c:/.../deLibraryCpp/src/de/Logger.cpp:15: [build] c:\...\arm-gnu-toolchain-12.2.mpacbti-bet1-mingw-w64-i686-arm-none-eabi\arm-none-eabi\include\c++\12.2.0\bits\allocator.h:46:10: fatal error: bits/c++allocator.h: No such file or directory [build] 46 | #include <bits/c++allocator.h> // Define the base class to std::allocator. [build] | ^~~~~~~~~~~~~~~~~~~~~ [build] compilation terminated.
Moved to Compiler-specific forum
