Licensing: Is it possible to use a MDK Essential (Flex) License for a standalone compiler in Linux?
Hey guys,
is using the standalone compiler valid usage with this license and in case it is, how do I get there?
The instruction page https://developer.arm.com/documentation/ka004977/latest does not list the MDK license.
In Windows we copy our mapping file from the µVision installation folder into the mappings folder of the standalone
compiler and set the ARMLMD_LICENSE_FILE and ARM_TOOL_VARIANT accordingly.
This approach does not work in linux, instead this failes with the following message
armclang: error: Your installation could be misconfigured or corrupted.
Check that your licensing and toolkit configuration is set up correctly, using the information available at: https://developer.arm.com/tools-and-software/software-development-tools/license-management/resources/product-and-toolkit-configuration.
Information about this error is available at: http://ds.arm.com/support/lic86
 General licensing information is available at: http://ds.arm.com/support/licensing/
 If you need further help, provide this complete error report to your supplier or license.support@arm.com.
 - ARMLMD_LICENSE_FILE: 'PORT@URL'
 - LM_LICENSE_FILE: unset
 - ARM_PRODUCT_DEF: unset
 - ARM_PRODUCT_PATH: unset
 - ARM_TOOL_VARIANT: 'mdk_cm_std_flex'
 - Product location: product not found
 - Toolchain location: .../ArmCompilerforEmbedded6.18/bin
 - Selected tool variant: mdk_cm_std_flex
Product: unknown
Component: Arm Compiler for Embedded 6.18
Tool: armclang [5e4cc700]
Appreciate any hints, thanks ;)
  • I had the suspicion, my license only supports older version, so I switched to Compiler Version 6.15. Furthermore there was a typo in my mapping file. Now I get this pretty clear message:
    armclang: error: Failed to check out a license.
    The provided license does not enable these tools.
    Information about this error is available at: http://ds.arm.com/support/lic56/m5
     - ARMLMD_LICENSE_FILE: 'PORT@IP'
     - Product location: .../ARMCompiler6.15/sw/mappings
     - Toolchain location: .../ARMCompiler6.15/bin
     - Checkout feature: mdk_std_compiler5
     - Feature version: 5.0202010
     - Flex error code: -5
    Product: MDK Plus 5.36 (Flex)
    Component: ARM Compiler 6.15
    Tool: armclang [5dd79400]
    Is there a way, to see which compilers are included in my license?
  • Though I have not tested, I suspect you need to undefine ARM_TOOL_VARIANT and point ARM_PRODUCT_DEF to the appropriate mapping file (from //Keil_install_dir/ARM/sw/mappings), essentially the same as the instructions are for an Arm Development Studio license.
  • Thank you, it indeed was a problem with the mapping files. I kept the environment variables as described. But got another mapping file from a colleague which fixed the problem.
