hello,
I use arm-gnu-toolchain-11.3.rel1-x86_64-arm-none-eabi on linux host.
I need `PATH_MAX` symbol that usually I get including (directpy or indirectly) limits.h. It the include sys/syslimits.h that actually defines PATH_MAX.
PATH_MAX
limits.h
sys/syslimits.h
until version 10.3 (which I was using previously), including limits.h would load the file lib/gcc/arm-none-eabi/10.3.1/include-fixed/limits.h which in turn includes lib/gcc/arm-none-eabi/10.3.1/include-fixed/syslimits.h which finally (via #include_next) includes arm-none-eabi/include/limits.h (which allows PATH_MAX to be declared).In the latest 11.3 release, however, the file lib/gcc/arm-none-eabi/11.3.1/include-fixed/limits.h does not include any other files, so the chain of inclusions is not triggered. And I have no way to directly include the file arm-none-eabi/include/limits.h.Trying to include syslimits.h (that makes lib/gcc/arm-none-eabi/11.3.1/include-fixed/syslimits.h to be included) instead I get an error:
#include_next
syslimits.h
/opt/arm-gnu-toolchain-11.3.rel1-x86_64-arm-none-eabi/arm-none-eabi/include/limits.h:132:26: error: no include path in which to search for limits.h 132 | # include_next <limits.h> |
best regards
Max
I investigated further, comparing the toolchains gcc-arm-none-eabi-10.3-2021.07 and arm-gnu-toolchain-11.3.rel1-x86_64-arm-none-eabi (and their sources).
The lib/gcc/arm-none-eabi/10.3.1/include-fixed/limits.h file is what I'm interested in in this context and what changes between the two versions.
In the old version that file has two inclusions that are not there in the new version, and they are exactly what I need.
Looking in the gcc sources I saw that the limits.h file can be the concatenation of gcc/limitx.h, gcc/glimits.h and gcc/limity.h or just the gcc/glimits.h file, here is a Makefile.in chunk:
gcc/limitx.h
gcc/glimits.h
gcc/limity.h
Makefile.in
if $(LIMITS_H_TEST) ; then \ cat $(srcdir)/limitx.h $(srcdir)/glimits.h $(srcdir)/limity.h > tmp-xlimits.h; \ else \ cat $(srcdir)/glimits.h > tmp-xlimits.h; \ fi; \
the choice depends on the value of LIMITS_H_TEST which is still populated in the makefile:
LIMITS_H_TEST
# Test to see whether <limits.h> exists in the system header files. LIMITS_H_TEST = [ -f $(BUILD_SYSTEM_HEADER_DIR)/limits.h ]
I bet <limits.h> file in the system header files is provided by newlib. Evidently when gcc is compiled, newlib has not yet been compiled/installed, so the <limits.h> file turns out not to be present and thus the include-fixed/limits.h file is generated using only gcc/glimits.h with no other inlcusions in it.
<limits.h>
I took a look at the compilation of toolchain 10.3, in fact among other things the compilation order is:
So when gcc-final is compiled, the newlib has already been compiled and therefore LIMITS_H_TEST is true.
Instead looking at the file arm-gnu-toolchain-arm-none-eabi-abe-manifest.txt, if I understand correctly, and the order is followed, gcc is compiled before newlib.
That might explain it.Is this a bug?
