I'm having trouble getting an ARM Cortex M33 to stop at breakpoints using arm-none-eabi-gdb on MaxOSX.
Running "show configuation" inside the arm-none-eabi-gdb environment, I see that expat was excluded during the GDB configuration process. (--without-expat)
$ arm-none-eabi-gdb GNU gdb (GNU Toolchain for the Arm Architecture 11.2-2022.02 (arm-11.14)) 11.2.90.20220202-git Copyright (C) 2022 Free Software Foundation, Inc. License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html> This is free software: you are free to change and redistribute it. There is NO WARRANTY, to the extent permitted by law. Type "show copying" and "show warranty" for details. This GDB was configured as "--host=x86_64-apple-darwin19.6.0 --target=arm-none-eabi". Type "show configuration" for configuration details. For bug reporting instructions, please see: <https://bugs.linaro.org/>. Find the GDB manual and other documentation resources online at: <http://www.gnu.org/software/gdb/documentation/>. For help, type "help". Type "apropos word" to search for commands related to "word". (gdb) show configuration This GDB was configured as follows: configure --host=x86_64-apple-darwin19.6.0 --target=arm-none-eabi --with-auto-load-dir=$debugdir:$datadir/auto-load --with-auto-load-safe-path=$debugdir:$datadir/auto-load --without-expat --with-gdb-datadir=//share/gdb (relocatable) --with-jit-reader-dir=//lib/gdb (relocatable) --without-libunwind-ia64 --without-lzma --without-babeltrace --without-intel-pt --with-mpfr --without-xxhash --without-python --without-python-libdir --without-debuginfod --without-guile --disable-source-highlight --with-separate-debug-dir=//lib/debug (relocatable) ("Relocatable" means the directory can be moved with the GDB installation tree, and GDB will still find it.)
I'm using max OSX x86_64 and I downloaded the latest release of the toolchain here. I'm trying to connect to a GDB server, specifically an openocd instance:
openocd -f ../st_nucleo_u575zi_q.cfg Open On-Chip Debugger 0.11.0+dev-00755-g5e96b012a (2022-07-21-13:58) Licensed under GNU GPL v2 For bug reports, read http://openocd.org/doc/doxygen/bugs.html Info : The selected transport took over low-level target control. The results might differ compared to plain JTAG/SWD Info : DEPRECATED target event trace-config; use TPIU events {pre,post}-{enable,disable} srst_only separate srst_nogate srst_open_drain connect_deassert_srst Info : Listening on port 6666 for tcl connections Info : Listening on port 4444 for telnet connections Info : clock speed 500 kHz Info : STLINK V3J9M3 (API v3) VID:PID 0483:374E Info : Target voltage: 3.297196 Info : [stm32u5x.cpu] Cortex-M33 r0p4 processor detected Info : [stm32u5x.cpu] target has 8 breakpoints, 4 watchpoints stm32u5x.dap Error executing event halted on target stm32u5x.cpu: /usr/local/Cellar/open-ocd/HEAD-5e96b01/bin/../share/openocd/scripts/target/stm32x5x_common.cfg:75: Error: in procedure 'mmw' called at file "/usr/local/Cellar/open-ocd/HEAD-5e96b01/bin/../share/openocd/scripts/target/stm32x5x_common.cfg", line 90 in procedure 'mrw' called at file "/usr/local/Cellar/open-ocd/HEAD-5e96b01/bin/../share/openocd/scripts/mem_helper.tcl", line 32 in procedure 'stm32x5x_ahb_ap_non_secure_access' called at file "/usr/local/Cellar/open-ocd/HEAD-5e96b01/bin/../share/openocd/scripts/target/stm32x5x_common.cfg", line 105 at file "/usr/local/Cellar/open-ocd/HEAD-5e96b01/bin/../share/openocd/scripts/target/stm32x5x_common.cfg", line 75 Info : starting gdb server for stm32u5x.cpu on 3333 Info : Listening on port 3333 for gdb connections
Using the arm-none-eabi-gdb binary:
arm-none-eabi-gdb GNU gdb (GNU Toolchain for the Arm Architecture 11.2-2022.02 (arm-11.14)) 11.2.90.20220202-git Copyright (C) 2022 Free Software Foundation, Inc. License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html> This is free software: you are free to change and redistribute it. There is NO WARRANTY, to the extent permitted by law. Type "show copying" and "show warranty" for details. This GDB was configured as "--host=x86_64-apple-darwin19.6.0 --target=arm-none-eabi". Type "show configuration" for configuration details. For bug reporting instructions, please see: <https://bugs.linaro.org/>. Find the GDB manual and other documentation resources online at: <http://www.gnu.org/software/gdb/documentation/>. For help, type "help". Type "apropos word" to search for commands related to "word". (gdb) file wearable.elf Reading symbols from wearable.elf... (gdb) target extended-remote :3333 Remote debugging using :3333 warning: Can not parse XML target description; XML support was disabled at compile time warning: Can not parse XML memory map; XML support was disabled at compile time 0x08001d98 in HAL_GetTick () at /Users/charlie/Documents/placeholder/firmware/third_party/STM32CubeU5/Drivers/STM32U5xx_HAL_Driver/Src/stm32u5xx_hal.c:313 313 } (gdb) b main Breakpoint 1 at 0x80010c2: file /Users/charlie/Documents/placeholder/firmware/main.c, line 197. (gdb) monitor reset halt Unable to match requested speed 480 kHz, using 200 kHz Unable to match requested speed 480 kHz, using 200 kHz stm32u5x.dap Error executing event halted on target stm32u5x.cpu: /usr/local/Cellar/open-ocd/HEAD-5e96b01/bin/../share/openocd/scripts/target/stm32x5x_common.cfg:75: Error: in procedure 'ocd_process_reset' in procedure 'ocd_process_reset_inner' called at file "embedded:startup.tcl", line 876 in procedure 'stm32x5x_ahb_ap_non_secure_access' called at file "/usr/local/Cellar/open-ocd/HEAD-5e96b01/bin/../share/openocd/scripts/target/stm32x5x_common.cfg", line 105 at file "/usr/local/Cellar/open-ocd/HEAD-5e96b01/bin/../share/openocd/scripts/target/stm32x5x_common.cfg", line 75 target halted due to debug-request, current mode: Thread xPSR: 0xf9000000 pc: 0x08001bd8 msp: 0x200c0000 (gdb) si stm32u5x.dap Error executing event halted on target stm32u5x.cpu: /usr/local/Cellar/open-ocd/HEAD-5e96b01/bin/../share/openocd/scripts/target/stm32x5x_common.cfg:75: Error: in procedure 'stm32x5x_ahb_ap_non_secure_access' called at file "/usr/local/Cellar/open-ocd/HEAD-5e96b01/bin/../share/openocd/scripts/target/stm32x5x_common.cfg", line 105 at file "/usr/local/Cellar/open-ocd/HEAD-5e96b01/bin/../share/openocd/scripts/target/stm32x5x_common.cfg", line 75 halted: PC: 0x08001bdc Reset_Handler () at /Users/charlie/Documents/placeholder/firmware/third_party/STM32CubeU5/Drivers/CMSIS/Device/ST/STM32U5xx/Source/Templates/gcc/startup_stm32u575xx.s:65 65 movs r1, #0 (gdb) continue Continuing.
Of note are the two warnings "Can not parse XML target description" and "Can not parse XML memory map". AFAIK expat is an XML parser ... and it's missing from arm-none-eabi-gdb. So my guess is that's the cause of these two warnings.
The result is that I can successfully set breakpoints, but they are ignored. In the above example, the code never stops at the main() entry point. This behavior was described here too: https://github.com/earlephilhower/arduino-pico/discussions/457
