We are using the following GCC 11.2 compiler to compile the Dhrystone benchmark
https://developer.arm.com/tools-and-software/open-source-software/developer-tools/gnu-toolchain/downloads
Dhrystone
https://github.com/sifive/benchmark-dhrystone/blob/master/dhry_1.c
The compiler generates the following warning
warning: '__builtin_memcpy' writing 31 bytes into a region of size 0 overflows the destination [-Wstringop-overflow=] strcpy (Ptr_Glob->variant.var_1.Str_Comp, ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ "DHRYSTONE PROGRAM, SOME STRING");
We use the following command to compile.
aarch64-none-elf-gcc -c -O3 dhry.c
Why does the compile generate the warning and how to get rid of the warning?
Thanks,
Sugumar
