I am working on embedded RTOS for ARMv8M chipset. I have recently added C++ support for my OS. When I try to handle exceptions in my C++ application, my system is crashing with an imprecise Data abort exception. I am not able to pin point the exact instruction which caused the issue, but I think the issue is happening either in memcpy or verbose_terminate_handler API's.
Below is the abort call stack which I am getting.
_ZTSSt12out_of_range_ZNK3Foo9print_addEi /home/apps/examples/cxxtest/cxxtest_main.cxx:120memcpy /home/os/include/string.h:321d_growable_string_callback_adapter_ZN9__gnu_cxx27__verbose_terminate_handlerEv_ZTISt13runtime_error_ZNSt13runtime_errorD2Ev /home/external/libcxx/stdexcept.cxx:99_ZTISt13runtime_error_ZN10__cxxabiv111__terminateEPFvvE_ZSt9terminatev__cxa_throwcxxtest_main /home/apps/examples/cxxtest/cxxtest_main.cxx:502
I am using the LLVM C++ library and linking the libsupc++.a from the toolchain.
Toolchain version: arm-none-eabi-gcc (GNU Tools for Arm Embedded Processors 9-2019-q4-major) 9.2.1 20191025 (release) [ARM/arm-9-branch revision 277599]
I am using the same configuration for an ARMv7M based chipset and everything is working just fine. Exceptions are caught and proper error messages are printed.
I found some information related to similar issues and I have tried the following:
1. I tried to build the gcc toolchain from source by disabling --disable-libstdcxx-verbose to avoid verbose exception prints
2. Build my code with -mno-unaligned-access and use memcpy implementation from my own code
But, the above methods have not worked out. Any help would be highly appreciated!!
