There is an inline assembler code, and compiled okay with arm-none-eabi-gcc,
but there is error when built with armclang.
Here is the code:
//wrong-reg.c #include <stdio.h> #include <stdint.h> #define __asm__ asm volatile float __vabs(const float a) { //VABS{cond}.F32 Sd, Sm float result; __asm volatile("vabs.f32 %0, %1" : "=w"(result) : "w"(a):); return result; } int __vcvta_s32(float a) { int result; __asm volatile("vcvta.s32.f32 %0, %1" : "=w"(result) : "w"(a):); return result; } int main(int argc, char *argv[]) { const uint8_t n4 = __vcvta_s32(__vabs(1 - 32.f / 100.0) * 100.0); printf("now n4 is %d", n4); return 0; }
compiled with:
armclang --target=arm-arm-none-eabi -mcpu=cortex-m55 -O2 -g -c -mfpu=fp-armv8-fullfp16-sp-d16 wrong-regs.c -o wrong-regs.o
then it report:
wrong-regs.c:17:17: error: couldn't allocate output register for constraint 'w' __asm volatile("vcvta.s32.f32 %0, %1" : "=w"(result) : "w"(a):);
arm-none-eabi-gcc -mcpu=cortex-m55 -march=armv8.1-m.main+mve.fp+fp.dp -mfloat-abi=hard --specs=rdimon.specs -mfpu=auto -g -O2 wrong-regs.c -o wrong-regs-gcc
This command is okay.
Anyone has ideas?
PS,
armclang --version
Product: Arm Compiler for Embedded 6.17 ProfessionalComponent: Arm Compiler for Embedded 6.17
arm-none-eabi-gcc --version
arm-none-eabi-gcc (GNU Arm Embedded Toolchain 10-2020-q4-major) 10.2.1 20201103 (release)
Br,
Yingchun
int __vcvta_s32(float a);
float __vcvta_s32(float a)
00000000 <__vcvta_s32>:
0: febc 0ac0 vcvta.s32.f32 s0, s0
4: 4770 bx lr
__vcvta_s32(float):
vcvta.s32.f32 s15, s0
vmov r0, s15 @ int
bx lr
