Trying to compile gcc-arm-arm-none-eabi-abe manifest with the instructions provided in the releases notes of 11.2.
I created a folder 'arm-toolchain' which contains two subfolders, abe, and a 'build' folder.
Following the steps, I configure abe. Installed all dependencies I am able to. The following ones I can't seem to resolve
checking for autoconf... autoconfchecking for automake... automakechecking for libtool... noconfigure: WARNING: You should install autoconf, automake, and libtool
sudo apt-get install libtool succeeded, yet this warning remains.
When I continue to build the toolchain with
../abe/abe.sh --manifest gcc-arm-arm-none-eabi-abe-manifest.txt --build all
I get the following compile error:
In file included from /usr/include/signal.h:328, from ../../gnulib/import/signal.h:52, from targ-map.c:7:targ-map.c:412:17: error: initializer element is not constant 412 | { "SIGSTKSZ", SIGSTKSZ, TARGET_SIGSTKSZ }, | ^~~~~~~~targ-map.c:412:17: note: (near initialization for ‘cb_init_signal_map[18].host_val’)
Who can help me further?
Many thanks!
