I am trying to build pyarmnn 22.08 on raspberry pi os 64 bit (Buster). while trying to compile it i get the following error
src/pyarmnn/_generated/armnn_wrap.cpp:2951:10: fatal error: ProfilingGuid.hpp: No such file or directory #include "ProfilingGuid.hpp" ^~~~~~~~~~~~~~~~~~~compilation terminated.error: command 'aarch64-linux-gnu-gcc' failed with exit status 1
p.s. I was able to compile the 20.05 version without any problem at all but unfortunately 21.11 or 22.08 does not work and gives the above error
